wrong housing thermostat problems
have a 2007 h3 with the inline 5 cylinder 3.7 and the thermostat housing has a 90 on it pointing towards the front of motor the replacement at auto zone and o rileys has a inlet with it coming strait out of the motor going towards the passenger side of the h3 went though every motor hummers came out with but none match the one on it the strait one would be coming though the power steering pump any one come across this problem
MOVED for you to the correct section. If you have a question regarding a H3, .............. ask it in the H3 section.
Order the correct GM T Stat parts from a GM supplier, like GMpartshouse.com or others. #305
Welcome to the forums.
hey,i just remembered, I checked my ps fluid sat and the pump is up on the right side where that rightangle thing is. it looks like a water hose fitting number 308. the STRAIGHT thing number 305 appears to be a housing for the thermostat.
so it depends on what you really need.!! I bet you did not find your t stat in the 308 thing!
raveniskcrow
01-30-2010 07:22 PM
c3 rolling
01-23-2009 06:30 PM
veves
05-31-2008 09:34 PM
