Wire Colors for Subwoofer
Old 11-23-2011 | 10:59 PM
austinoliveira's Avatar
Default Wire Colors for Subwoofer
I'm installing a subwoofer in my '08 H3 Alpha, and I need to get the wire colors for the subwoofer audio signal that run through the left side panels that run under the door. I have the power wire, ground, amp turn-on wire, and everything working properly, except for the audio signal. I used the left rear door signal, but that ended up not going anywhere below 40hz. Please help me out.
Old 11-24-2011 | 10:03 AM
drtom's Avatar
Banned
IM OUTTA TOWN so i cant look, but u can, just download the entire svc manual in 3 min for 15 bucks!
Old 11-24-2011 | 03:42 PM
Thanks, when you get home, could you check, that would be VERY helpful. I don't want to take apart the wheel well to get the signal from the sub itself, because that is too much work and I would probably break all the clips.
Old 11-25-2011 | 10:13 AM
drtom's Avatar
Banned
if u have a subwoofer u have a monsoon system right?
the sub is connected direct to the amp in the fender area. if you r replacing a sub you need to...replace the sub!! i dont know what else u can do!
if u dont have a sub, u dont have wires for a sub
Brent Whitfield
02-12-2014 07:40 PM
jasontag
04-26-2010 11:08 AM
mushyizcool
19
02-12-2008 09:26 PM
hummer
08-23-2007 05:49 AM
firefly38305
03-09-2007 02:11 AM
