wipers gone wild!!
wipers gone wild!!
my wipers will not shut off. anyone else have this problem? also, my mirrors will not fold in anymore, any suggestions on how to fix these problems and am i better off going to the dealer to have these problems fixed. i am out of warranty.
thanks,
bob
thanks,
bob
RE: wipers gone wild!!
He said he was OUT of warranty. So, if he goes to the dealer, they will charge him for to repairs.
I haven't a clue, but it sounds like you have a bad switch or short somewhere. As for the mirrors, they are probably just gummed up with crud. Try presure washing the area where they pivot to see if you can clean the crap out.
I have heard of this before on other boards, something to do with PDU? Expensive!!!
http://www.hummertech.net/Electrical.../m_1315/tm.htm
bbunevich
Sound like the circuit board in the wiper motor is bad. The solder joints crack causing the wiper motor to continue to run. It also causes the wipers to come on by them selves. The circuit board will need to be replaced. This involves removing 3 torx head screws and disconnecting the wiring harness after doing that remove the black plastic cover and remove the circuit board. Install the new circuit boaed, cover, 3 screws and the harness. that should cure the problem.
Good Luck
Good Luck
zoorda
12-29-2008 12:28 AM
