winshield wiper fluid pump quetsion
Driving along today, the front windshield wiper fluid stopped working. No sound of a pump working when I turn the trigger on the wiper controls. The back fluid works fine and I can hear the pump.
My question: Is there one or two pumps for the front and back nozzles? If there is only one pump then I know it is a problem with the trigger. If there are two pumps, time to get out the multimeter.
There are 2 pumps and they are on the reservoir The one toward the rear is for the front washer and the one toward the front is for the rear washer. Not hard at all to replace and it is much easier if you remove your airbox. There was a TSB's on the 06's. I don't know about the other years. I hope this helps.
Any idea which fuse it is? The manual shows fuse #16 is the rear wipe pump switch fuse but does not specify which one works the front pump. I went ahead and checked every one associated with the wipers but just curious.
That's what I am thinking. Either that or just a loose connection. I shot some silicon spray to a few connections to counteract all the salt just in case. Glad I did not have to replace the pump because I was not looking forward that with it being so cold right now.
John Taddeo
03-23-2009 08:51 AM
HummerDriver
07-11-2007 04:53 AM
HummerGuy
05-31-2007 07:47 PM
