winch for hummer
Old 01-28-2008 | 02:25 AM
speedster's Avatar
Default winch for hummer
Warn Winch Direct has good deals on winches but I don't thibk they have some winch for hummers.. where can i find some?
Old 01-28-2008 | 08:05 AM
Trey124's Avatar
Default RE: winch for hummer
Look at our sponser sites or try trail duty or boulderaccessory websites.
Old 01-28-2008 | 10:11 AM
My H1 winches are Warn. Mile Marker makes winches for Hummers. I know Warn makes a winch for the H2. Not sure about the 3.
Old 01-28-2008 | 10:16 AM
shortbus's Avatar
perhaps if you stated which Hummer model you wanted a winch for you might get a more detailed answer, maybe even some model numbers
Old 01-28-2008 | 11:03 AM
djbrow3's Avatar
I didn't realize winches were made based on vehicles? When I was looking for mine for the H3 I looked at ratings, cost, load limit, etc. As for fitting, they all fit the vehicle, just needed to get a mount for it.
Old 01-28-2008 | 11:55 AM
The H1 uses a 12,000# winch because the vehicle weighs 8000#. The H2 generally uses an 8000# winch because it weighs 6000#. An H3 uses...well you get the picture. Provide as much info as possible and our answers can be much more informative and accurate for your situation.
Old 01-28-2008 | 12:00 PM
shortbus's Avatar
i've got the warn 9500 TI on the bus. strong enough to snap a 14,000 lb pull pal when trying to pull an H1 sideways on ice. no idea how much force we were actually applying, since we had 2 ****** blocks in use as well . . . . . . .
Old 01-28-2008 | 01:38 PM
Also I know that due to the weight of the winch the H1s with winches have heavier duty springs on the front than the non-winch trucks.
Old 01-28-2008 | 02:39 PM
Leicajh's Avatar
This is what I have on my H3.
http://www.4wheelerssupply.com/catal.../468_2_702_705
Old 01-28-2008 | 09:04 PM
SafariHummerH2's Avatar
Yes.....I also have a 8000lb Warn Winch on my 2003 H2. I purchased my pre-owned Winch through a local posting in craigslist.com. I guess I was lucky to find a name brand such as WARN.
I also purchased from ebay.com the needed front Hitch mount extension and the Winch Hitch mount Plate.
I could have purchased in ebay a comparable no name brand Winch at a reasonable cost but a piece of equipment like this, You want a good strong Winch that is reputable and manufactured with quality. Although the name brand Winches tend to be a bit expensive. So I waited to find one pre owned at a reasonable price.
ebay also has name brand Winches but tend to be a bit pricey.
Currently I have it mounted to my vehicle, but not connected to the power yet since I'm trying to locate Power Quick Disconnect Plugs. But I did try to use it or rather test it out by connecting my Battery Jumper Cables to it and it worked perfectly!
Safari Hummer H2
