Winch for the H2
Old 04-20-2007 | 01:01 AM
RickLF's Avatar
Default Winch for the H2
I would like to Install a Winch on the H2, its from my understanding that you should Double the pulling power based on the total weight of your truck, for a single line pull.........
Warn has a winch for the H2 w/cradle thats 9,500 lbs......My truck weighs 7,400 lbs loaded as it sits......
what will the front Class 2 hitch hold in the front bumper?? Will it handle a 14,000 lb pull at 125ft
If you have a Winch on front of yours, what are you using and what are your recommendations....
Are You using wire rope orNylon Winchrope.......
Whats the best Winch to buy???
Thanks..........Rick
Old 04-20-2007 | 01:45 AM
shortbus's Avatar
Default RE: Winch for the H2
i've got the warn that plugs into the hitch receiver, 9500. haven't had an issue with it yet, regardless of the weight rating. snapped a 14000 lb pull pal with it, so i think it's strong enough for whatever the H2 gets into.
helium3
05-11-2013 03:01 AM
Mustanggirl666
11-26-2012 08:15 PM
TerpGuy
08-21-2010 11:41 PM
parishh3guy
07-31-2007 06:39 AM
CruisinCarAudio
04-03-2006 04:07 AM
