Will these wheels fit??
Old 04-26-2014 | 03:31 PM
Happy Hummer's Avatar
But than again some reports are 30 mm Offset.
Chris
Old 04-26-2014 | 09:32 PM
Bunger's Avatar
Originally Posted by Poweraidion
I found another set I like. Theyre also american outlaws. From what I read these ones should work. Will they? Sorry I'm still new to this and thanks for all the replies
4 New 17x8 5 15 Offset 6x135 American Outlaw Hollywood Black Wheels Rims | eBay
Nope, the bolt pattern is wrong & the hub bore is too small.
I just listed in the #4 post above, the 3 things that MUST match for the wheels to fit on a H3.
I wasn't kidding.
Old 05-15-2014 | 09:56 AM
razorbackfan's Avatar
Originally Posted by Bunger
Stock OEM 16" diameter wheel is 7.5" wide, 6x5.5"(6x139.7mm) lug pattern, 101 mm center bore, offset is 30mm, and back spacing is 5.5".
When choosing new wheels you need:
1) 6x5.5" lug pattern
2) 101 mm minimum center bore. (H3's are HUB centric, meaning that the wheels locate on the hub center, which is 100 mm, so you can't go too large on the center bore either)
3) 5.5" MAX backspace, less backspace will make tires stick out more as will wider wheels.
IGNORE offset, as it changes with wheel width. It's not an important number.
Will a 24x10 wheel that has a center bore of 87.1 and a +30 offset fit without any problems?
Old 05-15-2014 | 11:09 AM
Bunger's Avatar
You're joking, right?
If not, then I swear you guys don't read before you ask questions.
YOU quoted ME above, post #4, point #2 - 101mm MINIMUM diameter center bore to clear hub centers!
Old 05-15-2014 | 10:33 PM
Talking
You don't have to be a **** about it. Just asking a simple question, that's it.
Old 05-16-2014 | 05:14 AM
Don't forget point #3 also on his +30 offset
Old 05-16-2014 | 06:09 AM
Bunger's Avatar
Good point Taint, but I purposely didn't address that part.
Offset is a bull**** spec. It is confusing when trying to compare different width wheels. Backspace is the spec. needed.
Razorbackfan:
Here's an reference for wheel specs. You can see why 30mm offset on 7-1/2" wide wheels results in a certain backspace. You would not get the same backspace with 30mm offset on 10" wide wheels.
Backspace is an important number in order to clear suspension/steering/braking components no matter how wide the wheel is.
Old 05-16-2014 | 09:10 AM
Thanks for the info and I didn't mean to be rude. Just thought I would ask a few questions from you guys since you all know quite a bit.
Old 05-16-2014 | 10:46 AM
Bunger's Avatar
And I didn't mean to be a dick either.
Just so you know, those rims, even if the center bore was right, would have moved your tires out about 1-1/2 to 2". They most likely would rub severely in the wheel wells while turning.
Old 12-27-2014 | 01:46 PM
pace's Avatar
Bunger- Does your truck fit into a standard garage? I am getting the stealth rack and with 295/60/20 tires and slight level I'm worried it will be close... Thoughts?
