Will These 35's Fit?
Old 01-24-2010 | 11:32 AM
ShirtaDay.com's Avatar
Default Will These 35's Fit?
I found a good deal on a set of slightly used 35" tires and rims and I want to know if they'll fit our H3. I would only be using them on the weekends when off-roading. The wheels are "17x9in MotoMetal Chrome Wheels Unknown offset, came off of a Suburban 6x5.5 Bolt Pattern " and the tires "35x12.5x17 Dick Cepek Tires FC-II".
I know size-wise the tires will fit, but not sure if the rims will work.
Thanks in advance.
________
ford cd4e transmission
Old 01-24-2010 | 01:48 PM
slumlord's Avatar
Yes, they will fit! I had to add 3/8 inch spacer plates to stop the inside knobbies on the tires from rubbing the 1 inch round sterring stab bars when i had it held hard right or hard left. Doesn't rub or touch anything even going through big dips and bounces until I held the str. wheel hard either direction. The plates stopped it for me.
Old 01-24-2010 | 04:51 PM
I'm not so concerned about the tires as I am about the wheels fitting on the H3. Something about needing large centers?
________
arizona medical marijuana dispensary
Old 01-24-2010 | 05:07 PM
4DIGR's Avatar
The tape measure is your friend, or contact the mfg., their info will probably be most accurate.
Diablito
06-06-2010 10:12 PM
c3 rolling
10-20-2008 02:14 AM
Venom
05-26-2008 06:12 AM
Yankees31
06-14-2007 11:46 AM
gdfthrschill
04-28-2007 03:19 AM
