Will 4.56 gears from an I5 fit in an Alpha
I don't forsee any negative change in milage. I actually think that the mileage will increase as it did in our XJ with 33s going from the 3:55s to 4:11 gears. Went up 2 mpg overall after the correct speedo gear was installed!!!
I am not sure if you will need any "new" carriers, shims or anything else if you use the Alpha diffs. I plan on swapping in entire diffs (front and rear) from our H3T Adventure (4:56s locked front and rear) before selling it. YES, we will be relacing it with another H3T, getting and Alpha this time!!!
ANY, H3/H3T that came with either an Alpha 08-10 or a front locker 09-10 I5 Adventures and Alpha OffRoads have the Cast Iron Front Differential Housing.
I had it priced out a few months ago (I don't do re-gears and locker installs but I will do a front diff.) and they wanted just as much for the gears, install and locker as I could get the entire front diff. assembly complete with 4:56s and Eton locker. Might want to check the GM online parts places and see what the cost of a "complete CI diff" is compared to the re-gear.
If you wheel your HUMMER, might as well put a front locker in there while they have the front diff open. It shouldn't cost anything extra for the locker install except maybe drilling a hole for the air line or electrical connection.
I have broken H3T 4.56 HC4 rear axel 90% prts are good has 8000 miles on it, let me know if you want to do the gear swap.
I am not sure if you will need any "new" carriers, shims or anything else if you use the Alpha diffs. I plan on swapping in entire diffs (front and rear) from our H3T Adventure (4:56s locked front and rear) before selling it. YES, we will be relacing it with another H3T, getting and Alpha this time!!![/quote]
CarlosC
10-23-2009 10:54 AM
