Where's the radiator drain petcock?
Old 05-17-2011 | 03:05 AM
skeeet's Avatar
Default Where's the radiator drain petcock?
I think I looked all over for it. Does the H3 have a radiater drain petcock? Is there an engine drain plug?
I
Old 05-17-2011 | 10:43 AM
JCA1981's Avatar
From: The Empire State... should be called The Nanny State
There is none. With coolant service intervals much higher now I believe they've done away with them or so that's how I understood it. If you are doing a drain/flush of the coolant system, you might want to check this thread out:
https://www.hummerforums.com/forum/h...pletely-23791/
Old 05-17-2011 | 10:49 AM
JCA1981's Avatar
After taking a second look, I just realized you started the thread I posted above to try to help out. Sorry, didn't put 2 & 2 together until now. Doc explains there why the H3 doesn't have the radiator drain plug though and how to change the coolant.
Hope your thread helps... lol
Old 05-17-2011 | 12:33 PM
Draketh's Avatar
How about the 5.3L? Does it have one? I'm going to need to wrap up all of my 50k service soon.....
Old 05-18-2011 | 02:02 PM
JCA1981's Avatar
I'm unsure about the V8 application. Any Alpha owners out there change their coolant yet?
Also, might want to check what's talked about in this thread while you're changing the coolant/poking around the radiator:
https://www.hummerforums.com/forum/h...-leaked-21184/
DOC4H
08-16-2017 08:59 AM
Mad Professor
12-25-2011 01:08 PM
Antonio Dom.Rep.
06-24-2008 12:23 PM
josh1899
03-22-2008 11:52 AM
HummerfromClemson
12-29-2006 11:12 PM
