Where can I get keyless remote start?
Does anyone know where I could get a keyless remote start that would integrate with factory system. Would love to be able to have my H3 start up and get really chilled down before I get to it, on these hot Texas days. Any ideas of where and how much, I could get it for?[8D][8D][8D]
[IMG]local://upfiles/2219/35CAFCF3AD05424B9B92A582AFC640E8.jpg[/IMG]
RE: Where can I get keyless remote start?
Your dealer may have them. I went that route ONLY because then I don't have ANY WARRANTY PROBLEMS.
Any High End Car Audio place will also carry them.
I have the Compustar Pro P2W9000FMR. It's COOL!! The tech at my HUMMER dealership set it so when I start it in the winter, the heated seats come on!! Around $500 installed.
http://compustar.org/
[/align]
Up to 3000* feet of Range
This new CompuStar Pro 2W9000FMR remote has a built in clock, in-vehicle temperature readout, and battery voltage sensing. This system operates at a higher frequency to allow for greater range and battery life. Firstech engineers were the first to perfect 900MHz FM for vehicle security applications and we've taken this technology to the next level with the 2W9000FMR Pro.
*Range is quoted for U.S. models only. International models will differ in range.
Includes 1 x Two-Way and 1 x One-Way remote
View the manual for the P2W900FMR
[/align]
Pro Remote Features
- Two-way paging remote
- New multi-color LCD (liquid crystal display)
- CompuGlow backlight
- Vibration and audible notification
- Clock display with alarm
- Internal vehicle temperature display
- Parking Meter timer
- Button lock
- Timer Start Mode
- Cold and hot starting with temperature
- Run-time indicator (extendable with remote)
- Turbo Timer (extendable with remote)
- Secure Auxiliary Mode
- Shock sensor on/off through remote
- Passive mode on/off through remote
- Valet mode on/off through remote
- Uses standard AAA 1.5 volt battery
[/align]
Pro Alarm Features | P2W9000FM-A
Pro Starter Features | P2W9000FM-S
Pro Alarm/Start Features | P2W9000FM-AS
- Includes starter-kill relay
- Battery backup capable
- External Siren (six-tone)
- Optional super bright blue LED
- Driver's priority unlock
- Ignition controlled door locks
- Includes dual stage shock sensor
- Secure valet switch
- Anti-Jacking mode
- Remote Paging System (can unlock vehicle via pin code)
- 2-auxillary outputs, expandable to 7 with Channel Expander
- 2-programmable inputs
- Selectable trunk release output
- Horn trigger output[/align]
- Includes anti-grind and starter-kill relay
- Factory Style Alarm, monitors doors and trunk
- Time start set on remote by user
- Optional external Siren (six-tone)
- Diesel timer built-in
- Manual transmission compatible[/align]
- Anti-Jacking mode
[/align]
[/align]
Pro Remote Features
- Button lock
- Timer Start Mode
[/align]
- Anti-Jacking mode
- Anti-Jacking mode
[align=center]
[align=center]
ORIGINAL: whitestick
Thanks folks. That sounds like what I want. Question for HummBob:
Does this integrate with the factory alarms and locks, and do you just use this remote, rather then the original that came with the H3 for unlocking the doors, etc?
Does this impact OnStars ability to unlock the doors and do all their magic that they do?
The remote is programmed to lock/unlock your doors/hatch so you only have to have the 1 remote on your keychain.
Doesn't impact OnStar at all! They can still do all their tests or whatever as well as open the doors.
Hope this helps. It's an AWESOME system. I've been using Compustar for YEARS!!
varun
06-08-2012 05:06 PM
rmoore
12-22-2008 09:36 AM
