what tires?
RE: what tires?
Plug in the numbers to see how they fit. Kumho MT71, Hankook has a new AT out, Cooper, Procomps,General AT2 Grabber.
http://www.wheelsmaster.com/rt_specs...oliath%20Kumho
OEM tires: 265/75-16 (802x265mm). Big Hub.
32 x 10.5 x 16
Bolt OEM tires: 265/75-16 (802x265mm).
Bolt pattern: 6x139.7 (6x5.5).
Offset: 15 to 35 mm.
Tires up to 842x305mm.
Rims up to 26x10.0".
265/75R 16 = 32 X 10.50 X 16
265/70R 17 = 32 X 11.50 X 17
275/70R 17 = 32.50 X 11.00 X 17
285/60R 18 = 32 X 11 X 18
32 x 10.5 x 16
RE: what tires?
I'm still on the OEM Goodyear Wranglers. Do any of the more aggressive tires that have been suggested come close to these in terms of on-road noise levels and snow/ice performance? I'd likely stay on the 265's or only move up to 285's.
RE: what tires?
You can find BF Goodrich BFGoodrich All Terrain T/A KO LT315/75R16/D for $185 a piece fromDiscounttires.com then print out the page andyour localNTB will price match them. That's how I got my 305s locally really cheap.
I need a reccomendation on wheel spacers as I kept my factory rims and the 305s rub on the t-bar (or whatever that bar is)when turned all the way left or right. I don't want to over do it with spacer size. Any advice?
Nova...
Nova...
RE: what tires?
If you go with 35's your Speedometer will change, so you will have either figure it out and put a note on your dash or re-program the tranny/pcm. Well if you go with a p-metric tire you will have a UTQG rating and the higher the UTQG rating (300 soft- 500 hard) the harder the tire. If you get a LT (Light Truck) you will be getting a stiffer tire with a higher load rating but usually they and off-road tires do not have a UTQG rating. If you are looking for a quiet stock size tire. Here are my suggestions: Pro-Comp AT, Hankook RF-10, General AT2 Grabber, Dick Cepek FCII, BFG AT/KO, Toyo Open Country AT, GoodYear Silent Armor, Kumho MT78 AT,
RE: what tires?
If you go with spacers try to keep within the stock offset/backspace 15mm-35mm so there is no undo stress on wheel bearings. If the rim has a 35mm offset you will need a 1" spacer. reason being the 265 tire is 10.4"s wide and the 305's are 12" so you have a 1" deeper tire width, thats why it rubs your Tie-rod or A-arms. In my previus threads I placed a website that gives you a good picture of tire fitment. If you plug in the stock then the size you have it will give you information to help you correct your rub.
