Water Methanol
Water Methanol
has anyone tried water meth injection in their turbo diesel H1's. I am just curious I know this adds alot of timinghence raised cylinder pressures but I was wondering if it may have a significant cooling difference.
RE: Water Methanol
I've never seen a hummer guy do it but I've seen a couple people put it on there mid-90's chevy trucks with the same engines without much luck. The 6.2s/6.5s are pretty much at there performance capacity with stock cylinder pressure, especially the block - 2 out of the three I know who did it cracked blocks within several thousand miles, and the third got rid of his before it cracked - he had made it to about 8000 with the water meth
RE: Water Methanol
ok there is a guy out there with water/meth injection in his H1.... heres a quote:
"You should consider the water/meth if you run it hard.
With the system on I rarely exceed 850. Plus there is a definite performance boost, specially with a 50/50 water/meth mixture. "
850 is deg F of EGT
sorry for not much info on it due to the older post has been deleted.
850 is deg F of EGT
RE: Water Methanol
heres another quote:
"Why waste your time with injection? Why not build an intercooler and go that route. You get better performance, more torque, and a bigger impact at highway speeds where you spend quite a bit of time.
Sure it's more expensive, but the benefits are better too. "
Propst72
05-05-2016 05:08 PM
jodoan1
01-04-2007 10:53 AM
importkiller
11-11-2006 03:07 AM
