Water in drivers side door window.
Anyone else having this issue. Whenever it rains or I go to car wash I get water down the drivers side door and the window gets covered with it whenever I roll it down then up. Its so bad I have to clean the window after roll down then up just so I can see out. I am still under warranty and I bought the car used.
Any thoughts?
Any thoughts?
"the window gets covered with it whenever I roll it down then up."
Yea - that's normal. That's why if I wash my truck and clean the windows I don't roll them down until its dry. That's not something unique to HUMMERs.
Now if water is coming in when the window is closed, that could be a problem, but that doesn't sound like what's happening.
Must not have explained it properly. This only happens to the drivers side. I can roll up and down the passenger front and rear windows with no issue.
The water will stay in the drivers side door for days after washing or a good rain.
weather seal I think did not no if there is an adjustment trick or if other had a fix for this issue.
is all the weatherstripping on properly? Also, may want to check the top drain on that particular corner.
When I bought my first H2, it had only 19 thousand miles on it and in that short time, a lady always parked it under a pine tree.
Well needles and all sorts of tree stuff stopped up the drain causing water to try to come off of the roof around the door.
I ended up taking off all the plastic and cleaning all the drains throughout the truck. Problem solved.
I am going out on a hunch that this is your problem but it is def something to check out. Also check out the weather stripping.
Man1nboat
01-27-2013 02:51 PM
Diablito
04-24-2010 05:59 PM
pcmommy
03-23-2007 03:53 PM
