Warning light
Old 07-17-2008 | 12:04 AM
eors's Avatar
Default Warning light
Hi guys just have a question about one of the warning lights on the dash
I have a 08 H3 3.7 litre right hand drive.
On the dash above the high beam indiactor light there is a cross section of a tyre with an exclamation mark in the centre of it and the light is orange in color.
There is no explanation of what it is for in the owners manual
Any help would be greatly appreciated
Old 07-17-2008 | 05:28 AM
hummerabia's Avatar
Default RE: Warning light
Its the low tyre pressure warning light, and if I am not mistaken the South African built export models do not have the low tyre pressure warning system. So I guess you'll never see it lit.
Old 07-17-2008 | 08:12 AM
eors's Avatar
It lights up when you turn the key on but then disappears once the engien is running
Old 07-17-2008 | 08:23 AM
Trey124's Avatar
It is the tire pressure sensor. If your tires have the sensors in them and your pressure drops below a set level that would light up to let you know.
Old 07-17-2008 | 09:37 AM
HumV's Avatar
Yea mine came on the other day , I was driving for 3 1/2 hours and the during the summer the tire pressure change just like the winter. After i called onstar and asked them what it was they pretty much said the same thing that the tire pressure changed. a day later it never came back on. Assuming the tires where extremely hot and the tires were over inflated.
Old 07-17-2008 | 08:55 PM
eors's Avatar
Thx for the help guys...pity we dont have that option in Australia.
Any one know if the system would be able to work if you got the valve sensors?
Old 07-18-2008 | 11:02 AM
Actually....IMHO the Tire Pressure Monitor Sensors are a PITA!
Many, many people have had false warning issues, and rotating the tires takes longer because the wheels are relocated and the system needs to be
programmed to re-set the location of each after rotation. It is not difficult, just takes time....[&o]
Old 07-21-2008 | 06:08 AM
hummerabia's Avatar
Agree with you there Doc, my '06 had TPMS and it was a PITA,I had to re-set it several times and had a gas station attendant snap one valve off resulting in a $100 replacement sensor assembly plus tyre removal / balancing. My '07 hasn't got it thankfully, one less electronic gizmo to worry about.
Old 10-30-2009 | 06:19 PM
bubba's Avatar
can anyone tell me how to reset tpmonitor and the location of it
Old 10-31-2009 | 01:31 AM
RKSmith163's Avatar
I have rotated my tires three times now and the last two times I did not do the reprogramming procedure just to see what would happen. The TPMS did not come on in either case. I know the manual says to do it. Perhaps since the H3 doesn't indicate which tire is low, it really doesn't care as long as they are all the same and not over or under pressure. That's my theory anyway.
Brinleigh217
02-12-2018 01:19 PM
Champ53
07-19-2011 03:26 PM
mbowman90
01-25-2010 06:03 PM
drtom
01-02-2010 12:50 PM
NIK1
12-08-2008 12:44 PM
