vibration underneath...1800-1900rpms
ok....so my H3 has been in the shop already for this issue....first time they found missing bolts from the skid plate....vibration noise is back...
this time they say its on the exhaust...
anyone have this and what was the outcome ?
thanks
thanks
RE: vibration underneath...1800-1900rpms
I had this vibration...does it do it when you "power brake" (put it in 'D' put on the e brake, push in the brake pedal as far as you can and push the gas til you get to the vibration mark)?
If so..the solution takes about2 minutes. there is a heat shield on the passenger side of the engine block...its shaped to look like the actual engine but its not..just a shield. Thats whats making the vibration...sometimes while changing the oil, this gets bent to touch the realengine block. grab the bottom of the heat shield and pull it away from the engine. It doesnt take much but thats what my vibration was.
I had the same vibration. Drove me nuts! I got it fixed at the dealer today. He said it was a transmission line (a metal line) that had come out of a retaining clip and was vibrating against something. They replaced the clip and secured the line. I've put about 50 miles on it noise-free!
I also had the regular maintenance done -- oil, filters, alignment, etc. The truck runs great!
-Alan
-Alan
buy-hummer
03-24-2014 09:22 PM
mailman2000
16
03-17-2009 08:28 PM
cheyenne95129
12-04-2008 03:31 AM
whododat
08-14-2007 01:04 PM
HingHum
03-20-2007 06:18 PM
