Vibrating headlight
Old 02-03-2009 | 10:29 PM
hotrod's Avatar
Default Vibrating headlight
The pass headlight bounces when I hit bumps in the road. It didn't do this when I bought it. I haven't removed the grill to check it out yet (too cold). Has anyone else had this problem?
Old 02-04-2009 | 05:30 PM
wfturner's Avatar
There is a chance that one of the three spring latches has come loose from the round screw heads.
Each headlight assembly attaches to the headlight bucket with three legs and a spring catch at its end of each leg
You must first remove the grille and look with a flashlight, behind the head light housing to determine why it is loose and go from there
Old 02-04-2009 | 05:59 PM
hotrod's Avatar
Thanks tuner
Old 02-05-2009 | 09:08 AM
wfturner's Avatar
Originally Posted by hotrod
Thanks tuner
You're welcome, but I'm "turner"
Also to remove headlight, you must grab headlight on left and right with both hands and pull
straight out. It takes a fair amount of force, but the headlight will snap off the three post screws.
PKJ
09-04-2019 07:44 AM
H2Miami
07-10-2012 08:16 PM
markiemark
04-15-2010 01:13 PM
k6irf
12-10-2006 12:28 PM
egombrich
01-12-2006 05:53 PM
