Very weird electrical problem..PLEASE HELP!
Old 08-17-2013, 12:56 PM
jescobe82's Avatar
Default Very weird electrical problem..PLEASE HELP!
I have an 06 H3 adventure/luxury model with Monsoon system. When you moderately jump on the gas, the door chime goes off and the doors lock and unlock, and relock! It started only doing it when you really got on the gas, but now it does it almost every time just coming off of a stop sign or light. I have searched the threads and found nothing like this. I don't know where to begin looking for what causes this. I'm thinking something in the BCM but have no real clue. Has anyone else had this problem????? PLEASE share if you have and what was the fix. Thank you....
Old 08-17-2013, 01:00 PM
RKSmith163's Avatar
First thing I would check would be the battery connections and terminals.
Old 08-17-2013, 01:07 PM
jescobe82's Avatar
I did think of that and I just replaced the battery about 4 months ago. Everything looks good there. Thank you for the reply!
Old 08-17-2013, 03:57 PM
stubbsy's Avatar
My guess would be the switch that locks the doors when you select drive is loose or faulty, does it do it in reverse ?
Old 08-17-2013, 05:39 PM
happythree's Avatar
unhook,short toether,pause,reconnect.
I doubted it , then last week my h3 kept running when I pulled the key. did that,fixed!!
I guess its like c,a,d safe mode!
Old 08-17-2013, 06:10 PM
NJTEX's Avatar
It likely could simply be one of the door switches going bad. I'd start testing the one for the tailgate first.
Old 08-17-2013, 07:34 PM
happythree's Avatar
door sw?,,my door not closed the dic says, doors, and maybe a polite ding,no lock unlock clatter
Old 08-17-2013, 09:59 PM
egroegart's Avatar
NJTEX knows what he is talking about. It's easy to determine which switch is bad and about a $15 part. You will have these symptoms if one of the door switches are bad. You've got 5 switches, check them one at a time. I'll bet NJTEX is right.
Old 08-18-2013, 08:41 AM
happythree's Avatar
Default not hard to check
if you have a hummer handy,take a ride,unlatch a door and you will instantly know.
Old 08-18-2013, 09:49 AM
jescobe82's Avatar
I can sort of see if it's a door switch but what I don't understand is what does stomping on the gas have anything to do with the door switches? I do not have a door open message and the dome light works as it should. And to reply to an above question, I haven't tried it in reverse but I will do that today and see what happens. Thank you all for you input!!
Quick Reply: Very weird electrical problem..PLEASE HELP!
