Very Important ECu to BCM "QUESTION"
Old 09-22-2010 | 07:20 AM
FilthyKings's Avatar
Default Very Important ECu to BCM "QUESTION"
444444444444444
Old 09-22-2010 | 09:33 AM
85_305's Avatar
Banned
I'm thinking ANY bcm will work; but you have a very good chance of needing to go to the dealer and have it reprogrammed.
Old 09-22-2010 | 11:26 AM
Since H3s use a PCM, not an ECU, I think there is some confusion?
If what you are asking is: Will a stock 07 PCM work in a stock 06? The answer is NO.
07 PCMs will not work in an 08 because of the TCM. 08-10s are interchangable so long as the engine/trans pkg is the same.
Old 09-22-2010 | 12:09 PM
85_305's Avatar
Banned
Interesting; I thought they were all somewhat compatible, just the dealer had to reprogram them for your individual case?
Old 09-22-2010 | 04:34 PM
not a 2008..... 2007 computer with an 06 bcm
Old 09-22-2010 | 10:45 PM
I believe that a BCM (Body Control Module) from an 06 will not work in an 07 due to the fact that the 06 did not have SIRs (Side Impact Restraints/airbags) and most of the 07s did.
Old 09-23-2010 | 06:05 PM
Chunk54's Avatar
I agree with Tainter and the SIR issue. Aside from that, its a CAN system where all modules communicate back and forth with each other. Anything from A/C system operation to putting it in drive could be affected. But more importantly, why would you want so switch it?
Old 09-24-2010 | 09:13 AM
02-19-2014 01:54 PM
wantboost
16
09-08-2010 07:32 PM
CHINAHummerGirls
08-19-2010 04:36 PM
rocky27_9
01-27-2008 03:29 AM
xzachx2112
01-11-2008 07:20 PM
