Using wheel spacers with 35" MT's?
Hello All,
I recently added 35" Toyo MT's to my 07 H3 and cranked the torsion bars about 2.5 turns to raise the front end up a bit. I'm still experiencing a slight rub on the sway bars. Will utilizing 1/4 wheel spacers cure the rubbing issue without having to extend the wheel studs? I don't really want to go with a full 1 inch spacer as of yet to cure the issue since I have a set of 1/4 spacers on hand.
Mr. Gasket 1/4 Wheel Spacers 6x5.5
[IMG]local://upfiles/3607/AEFDA56CFF80400F8EBDB63FD3B3ABE4.jpg[/IMG]
RE: Using wheel spacers with 35" MT's?
It is just the foreign tires that rub! [8D][8D]
Here is an idea, how about do not turn your wheels so sharp unless absolutely necessary! Remarkable....problem solved.
chukwagen
02-18-2008 03:00 PM
