Upgrades done to brakes and much thanks!
Well I'm obsessed with this forum officially now and I can see it's going to cost me! I know I'm a newbie and shouldn't point fingers but thanks blackbear for the soundclip, Magnaflow is on it's way. Thanks alrock for the good comments on Airaid intake, that is on the way as well. I've decided to go with the 295/75R16 or 305/70R16 to stay in 33' land. I tow a 3500lb boat so the 35' concerns me a little. So with that, I have not run across brake upgrades yet. Have any of you done these? Slotted rotors, different calipers? I'm a Toyota truck/4Runner transplant so not familiar with the 'norm' or what's best on the H3. Once again, thank you all for the great information, my wife hates you.
RE: Upgrades done to brakes?
From a a post by me in prior thread on the topic:
There are several companies make good drilled and slotted rotors for the H3. I agree with the consensus, you do not need them for the 3. The 3 is one of the few GM trucks to have adequate brakes right from the factory. GM has been criticised for being too conservative in brakes for years. If you want the drilled and slotted rotors to show thru your huge chrome rims, go for it. They will eat pads like crazy because the cross drill slotted surface INCREASES BRAKE FRICTION even though there is less total rotor surface contact with the pad. You need to run a hard pad, like titaniums, and they still will be chewed up pronto. Your front pad life is probably less than 20k. Yes they eat pads! The cross drill technique is to increase air surface contatct for heat dissapation and minimize gassing in extreme conditions. The slots are to clean/strip pad surface to increase friction. In wet braking it is hard to beat a slotted rotor. Since we are not racing road courses in the rain, I'll pass on this mod.
Thanks Doc! I will leave well enough alone then. As for bling, what came from the factory (rims) is good for me. The only bling I'm adding is the chrome tips that come with the exhaust I ordered. But, maybe everyone should get some 'iced-out' badging. [:'(]
http://cgi.ebay.com/ebaymotors/Humme...spagenameZWDVW
I have to disaggree. The H3 may have better brakes but far from adequate for it's weight, especially if you are towing. The US auto industry is just starting to get decent brakes. To truly improve your braking you need to increase the diameter of the rotors or the number of pistons. Unfortunately that means upgrading to larger rims.
ORIGINAL: WillyH3
ORIGINAL: fineseeker
***** you should warn people before posting a link like that. I was eating lunch and almost puked it up.[:'(]
She said to tell you:
I like the brakes for the H3 though I hankfully haven't had to use them to desperation yet. As many of the towing threads say, if you are towing you do want trailer brakes. I don't think there would be an easy, reasonable upgrade to get a significant performance increase.
ORIGINAL: WillyH3
Cliff
ElGuapo
05-17-2015 07:34 PM
importkiller
20
02-21-2008 02:04 PM
