Up-Grade from the Tank Air Horn......H2
I had onour H2, the Air Horn that mounted to the Fire wall, though Loud, and expensive (air Pumps going bad).........
Ive found a New Horn toy, I have Installed a Federal 100 Watt Speaker Siren into the Front Grill and put a 100 watt Whellen PA/AIR HORN in to the drivers side of the H2..........
Its Loud and Noticable and makes no Noise, as the Tank pump did trying get filled again, for the next shot....
I have it wired thru- the horn Button, works great as loud if not Louder than the Hadley horn system, ended up costing $120.00 less than the tank system, the horn noise goes out the front grill instead of Blowing the air horns, Under the HOOD........
You can always use a 100 watt PA system, to (tell) Remind the person on the CELL phone, the Lights GREEN.......
RE: Up-Grade from the Tank Air Horn......
Hi MRDM1,
I bought them from:
www.emergencyvehiclesupply.com
Stock/Part Numbers:
PAP112 /Whelen power Air Horn/100W Plus PA, mike included ( not on there Internet site, Must call-to order)
You can buy them with a Siren, and tie it into your alarm system...I dident do that, I bought the one that had the Air Horn and PA Only...........Id be tempted to use the siren in Traffic.........don't need to be in Jail......
MS100 / (Federal Siginal Corp.) FSC MS100 dynamax speaker (on- web site)
8567079-A-01 / FSC UNV Bracket For MS 100 (on- web site)
There telephone Number is: 954-428-5201
Took me about 1 hour to install, used a Raido shack cig. plug with the switch on it to wire the air horn and bought 12 feet of 16 gauge wire Double and coverd from West Marine.........
Works Great............Going to enjoy taking it into the HUMMER Dealership for its Syn. oil change, when they test the Horns by hitting the Emergency button..........They will get a BLAST..........LOL
I bought them from:
Stock/Part Numbers:
Alex2012
07-11-2012 12:57 PM
