Unusual Sound, What could it be?
Today I noticed something I have not heard before. When coming to a stop ata light or stop sign just before the car stops I hear a grinding sound. At first I thought it was the brakes, but as I kept simulating it to test it I started thinking it was not the brakes. Maybe something in the front axle. It only does this right before the vehicle stops, not anywhere else in the braking process.
I will be setting an appt for an oil change tommorrow and want to know you thoughts before I take it in and the dealer gives me there thoughts. The vehicle has about 10,000 miles on it.
RE: Unusual Sound, What could it be?
Has the car been sitting for awhile????? If it has the disks could have rusted and the grinding is basically just taking off the rust. When i went away for a few weeks i had that issue with all the rain and everything my plates rusted and when i pressed the breaks it made a grinding noise until i cleared off all the rust. If not then i have no clue sorry
It could be that the front diff has lost some of its tooth (hope I spelled this correctly) and the loose metal there causes you to hearthese grinding noises.
I have3 friends with Toyotas that
I hope I'm totally wrong here
You mentioned rear brakes and slow speed sound just before you stop.See this: RE: Rotor resurfacing bulletin
I have the same type of sound just like you desribing. the dealer told me the with the 33" a/t tires that when you come to a stop the weight distribution to the fron puts extra pressure on these wheels and since they have a semi aggresive tread it will create a growl type noise that may not happen every time. makes sense to me.
ORIGINAL: RealJeep
This post keeps coming back.... Remember to use the SEARCH function to get quick questions answered.
[sm=goodidea.gif]
[sm=goodidea.gif]
I'm sorry, I did a quick search but the verbage must be wrong. I know I've seen this post before. HUMMER has a TSB out dealing with a vibrating/ growling noise upon moderately hard braking conditions. My H3 does it and it makes me crazy. When you step on the brake it has a weird sound/feeling like there's something grinding. What it's doing is the brake calipers are vibrating on hard braking causing the entire drive line to resonate a vibration. You can actually feel it in the brake pedal.
Does this sound familiar?
ORIGINAL: Doc Olds
Barrett
09-20-2012 11:35 AM
glen4cindy
04-27-2011 09:26 PM
ratrodchris
38
01-13-2009 07:38 PM
whododat
11-27-2006 04:10 AM
Greenblade
07-03-2006 06:17 PM
