turns on torsion bar adj level front
Old 07-30-2009 | 02:12 PM
Emptys_H3's Avatar
Default turns on torsion bar adj level front
Hi everyone,
I recently level my front suspension with the torsion bars wondered if these turns on the adjustment is normal. The turns on torsion bar to get 23 1/2" I ended up with driver side +9 turns and passenger +1 turns with 3/4 tank of gas, do the amount of turns vary per vehicle? I did drive the vehicle around a few blocks after each adjustments and I am on a level garage floor.
Old 07-30-2009 | 04:15 PM
The T bar adjustement to level is not by the # of turns. Yes, every vehicle would be different.
It is a matter of turn the bolt and measure until you get where you need/want to be.
I've done them before where we actually tightened on the driver side and loosened on the pssgr side to level it accross the front.
9 might seam high, but if you can read the tape measure, your good to go.
For the benefits of others, take a look at https://www.hummerforums.com/forum/f...splay.php?f=33 on this topic.
Old 07-30-2009 | 07:03 PM
Emptys_H3's Avatar
Thanks Doc,
I remember dmurdock how to but did it without the jack. I couldn't find any others on the # of turns on their torsion bars. The ones that did say basically had their desired lift within 2 turns. When I do get new leveling shocks we will see if there will need to be more adjustments. I've read a claim that the leveling shocks raised the front another 1".
Old 12-02-2009 | 10:12 PM
2wheelmonster's Avatar
this thread is very helpful
Old 03-11-2010 | 01:52 PM
psych0's Avatar
Originally Posted by Emptys_H3
Thanks Doc,
The shocks definately add height.... I did my adjustment on my old H3 and got it to where it was perfect.... then after the shocks were added it was high.
RedH3Guy
11-04-2014 02:25 PM
talusfan
03-18-2010 01:17 AM
mtrmble
04-02-2008 08:26 PM
jm4490
01-06-2007 04:52 AM
importkiller
05-23-2006 01:36 PM
