Truck won't turn over
Went to start truck after sitting for two days. Doesn't kick over and start. Battery brand new. Any suggestions??? Never had trouble before.
Hmmm... I know the feeling of needing to get home being far away. I would start with your ignition fuse to make sure you are getting power to the starter. After you have verified the fuse is okay, check the connection to the starter itself. It may have come loose causing your troubles. If that's not it, I'm not too sure what else to tell you.
So it IS trying to turn over. Sounds more like a spark issue. You made it sound like it wasn't doing anything. Well at least it's trying to. What kind of air filter are you running? If you have a K&N, a lot of the times the oil will foul out the MAF sensor which will also not allow the truck to start or stay running.
