troubles
Does your cruise still work?? I would think that it won't if there is a issue with the brake pedal switch. If cruise still works then maybe there is a short in the wiring somewhere. Does lifting up on the brake pedal do anything? Perhaps the brake switch is sticky or needs adjustment.
Let us know if you have further issues once you check it again.
PS, glad to see 04colyZQ8 knows his GMT 345 stuff once again!
"the fix"
i posted this somewhere last year.
if you have not had a failure YET, just reach the cable from underneath , lift and push forward to unhook the clip that causes the stress. leave it free and youre safe. if you made a repair,,DO NOT reuse the clip.
if youre a fraidy cat you might need to tie it loosley
madmike
02-12-2009 05:42 PM
ockie
07-26-2008 07:44 PM
