Tri-Phase Performance Module
RE: Tri-Phase Performance Module
The only difference in that product and the "performance modules" found on Ebay is that these guys are screwing you even harder and holding the Vaseline.
It's nothing more than a resistor.
Most likely placed at your IAT sensor (or MAF), this basically fools the computer into thinking it's receiving colder air, and thus advances timing and increases fuel delivery.
Get your ECU flashed for the same money and you will actually see some results...
I do agree with GarrettM. While not specifically familiar with the installation of this tri-phase product, I am most positive it is changing the voltage reading from the MAF to the PCM, you throw the switch to ++ and it gives you one additional change. Just fools the PCM into thinkingthat theintake air charge is cooler than it really is, thus more dense, and theoretically advances (VVT and ignition?) timing allowing a higher fuel ratio. Not very efficient because their are appx. 29-32 other available variables to account for more performance that are not being changed.
PCMforless tuning is actually cheaper than that Rube Goldberg set up.
Caraddict
12-12-2011 06:55 AM
marksteven
09-12-2010 08:01 PM
Ken06H3
04-13-2010 04:51 PM
TAINTER
01-16-2009 08:18 AM
2006, ecu, flash, h3, hummer, install, installation, installing, mafiat, module, perfomance, performance, phase, sensor, tri, triphase
