transmission help please
They said the problem is internally so i would have to get a rebuild for a total cost of $1600 before taxes, should i look for a used tranny then do a remove and replace or look into getting a brand new transmission altogether ?
A good transmission rebuild is fine, I like the GM rebuilt transmissions as they come with a great nationwide warranty. Is your shop sure it's the trans and not the transfer case? $1600 is not a bad price if they do a good job. If you are located in the so. cal area I can recommend a great trans shop.
That frightened me as well. I feel bad this happened to his truck and hope he gets the issues worked out with the drivetrain but you all should def. do a little research on how your truck works, its capabilities, and its basic dynamics.
"An ounce of prevention is worth a pound of cure." -Ben Franklin
EDIT: By you all, I meant the guys who didn't know much about their truck. A little knowledge might be able to get them out of a jam, or prevent a future jam. Wasn't referring to any of the guys trying to help them out and/or give them pointers.
HI, I am new to this board and a new H-3 owner, but I too have had a transmission problem identical to yours. I made a slow right turn and "BAM" then I could not go any faster than 30 mph !! Something in my tranny locked up and burned out all the clutches. Thankfully, I had purchased an extended warranty so the repairs only cost me the deductable. I just got my H3 back yesterday with a rebuilt tranny. Good luck with your H3. dan
Warrantee coverage??lukee u
im surprised anybody covers this in any warrantee, its driver inflicted damage!!
YOU SIMPLY CANT DRIVE THESE VEHICLES ON DRY PAVEMENT IN A LOCK MODE,,EITHER TIRES MUST BREAK LOOSE OR,,SOME OTHER PARTS MUST BREAK.
if an h3 gets in lo lock you can tell pretty quick, engine revs and u go slow and your brain should alert u that something is wrong,,,BUT ,,in hi lock its like hi norm,,,until u turn. the outside wheels must turn faster than inside,,OR SOMETHIN MUST BREAK,,THATS IT
i keep repeating this hoping to help. last july i got my first ever 4wd/awd and knew NOTHING so i paid attention when the salesman got awful nervouse when i wanted to see what lo lock felt like. he said,DO NOT TURN THE WHEEL. we went about 50 feet and shifted back to norm.
he explained and i read more about it
soon after,i wired up a flashing red led,right in my eyes in the dash,,LOCK MODE FLASHER.
A few mornings,after driving thru the back field the nite b4 in lock(as xercize for gears) i was greeted with the flasher. lukee me.
i also find it ez to bump a buttom and get in lock. i feel like adding a cover on the buttons.
so,,,face it guys, the warr guys are not going to eat this forever,,u better learn to or find a way to prevent it,,ot pay big$
tom
tom
So.., Dr Tom.. Sr Member... I never said I was in Hi Lock mode. I was not in Lock mode at all. BTW., According to my mechanic, and the adjuster, this is a common failure for this transmission. I've been driving Range Rovers for the past 6 years and have been in and out of tough terrain with them. So far, all the H3 has seen is highways and byways. in 4 high
