Transfer case overhauling
Old 10-29-2012 | 09:54 AM
Hummer_SG's Avatar
Default Transfer case overhauling
Hi all.
Can any 1 advice me what Type (name and model number) of transfer case on my 2009 Hummer H3 3.7.
Also where can I get replacement parts for the transfer case ?
Thank you.
Mike
Old 10-29-2012 | 10:49 AM
RKSmith163's Avatar
Both are Borg-Warner. The NR4 is for the None Adventure/Offroad. GM Parts House has them listed.
NR4 - B/W 4493 2.64 ratio.
NR6 - B/W 4494 4.01 ratio.
Old 10-29-2012 | 09:49 PM
Hummer_SG's Avatar
Hi mate.
Thks for your help.
What do you meant by non off road ?
So which model I transfer case below to ?
Thank you
Old 10-30-2012 | 09:45 AM
RKSmith163's Avatar
If you have factory locking differentials you have the NR6. If you do not, you have the NR4. On your 4X4 control panel lockers are indicated on a button represenative of 4 wheels with an X on axle that locks. 06-08 will only have 1 locker button 09 and 10's will have 2. The none Adventure/Offroad pkgs. will not have a locker button. I suggest you do some futher research on this forum to find out what you have and what it is used for before you go tearing into things. I hope this helps.
Old 10-30-2012 | 11:10 AM
Wayne Auto Ebay's Avatar
Yours is the NR6, it will have one of these ID Numbers
Hollander Interchange Notes:
GM 24247592
Ident: 24232752
Ident: 24235236
Ident: 24235696
Ident: 24236862
Ident: 24238072
Ident: 24240985
Ident: 24243592
Ident: 24245370
Ident: 24247879
Ident: 24252289
Ident: DA '06
Ident: EK '06
Ident: EP '06
Ident: EV '06
Ident: GH '06-07
Ident: LB
Ident: LX
Ident: NJ
GM opt NR6.
Old 10-30-2012 | 11:50 AM
Hummer_SG's Avatar
Thks Smith. Your are the man. I nearly order the wrong replacement parts.
Yes. My car are fitted with the original diff lock and indeed there are 2 diff lock.
So for NR6 is there a place online I can get spares or any website I can look for upgrades of internal parts.
Old 10-30-2012 | 01:56 PM
RKSmith163's Avatar
So your's is an 09 or 10 if it has front and rear factory differential locks. Replacement parts you can get at GM Parts House. I have no experience with upgrades so someone else will have to help you with that one.
ride450
06-26-2021 03:00 PM
hudson4269
03-07-2017 10:12 AM
Lewis N
02-03-2008 09:22 AM
mh307
10-16-2007 06:24 PM
07-19-2006 04:05 PM
