Transfer case front output seal replacement
Old 07-02-2023 | 11:06 AM
Dan2008H3's Avatar
Default Transfer case front output seal replacement
There is a leak from the transfer case in my 2008 H3, and I believe it is the #20 seal. I have removed the U-Joint end of the front propeller shaft and it is free. Do I need to remove the #21 Flange and #24 Nut to finish removing the propeller shaft, or does the propeller shaft just slide out, without removing the flange? Thank you!
Old 07-07-2023 | 01:30 PM
Take a look at the GM manual for the T Case, page 82 in the link below.
H3 Transfer Case
CarlosC
07-02-2023 10:46 AM
JimmyJack
01-09-2023 08:13 AM
LatvjuAvs
07-08-2020 01:02 PM
flyinghunter
16
04-30-2014 11:55 AM
bigstick0000
11-28-2012 10:06 PM
Quick Reply: Transfer case front output seal replacement
