Tires screeching on full turns?
Alignment on my H3 is spot on and it still squeals, always has done since brand new.
I am sure it has something to do with the fact that it is constant all wheel drive, I would hazard a guess that if it does not squeal you have some issues with your constant four wheel drive system getting worn and sloppy.
it not only has to do with the fact that it is full time four wheel but it is also dependent on the size of tire, brand of tire, and tread pattern of the tire. the smaller and stiffer the sidewall the more it'll squeal because the rubber isn't able to roll over as much, the tread pattern because the more street and all terain the more rubber in consct with the cement, and the brand because if it is a softer or harder rubber compound will make the biggest difference. just like on my caddy cts I had a very hard compound rubber and anytime I would do a burnout all it would do is smoke the tires, it wouldn't actually squeal them.
H3_2009
09-01-2010 05:19 PM
Emptys_H3
03-11-2010 12:52 PM
