Tires Rubbing
I have a 2007 Hummer H3 with stock rims and tires. I just had this problem pop up. When I turn the wheel sharply to the left or the right, the right front wheel will rub on something. Going in reverse is worse.
Any thoughts on what this could be?
u mite wanna turn sharply till it rubs,,,turn off your motor,,,put the e brake on.
get out and see whats rubbing
i think ure in a lock mode and hearing racket from the binding of the drivetrain
just guessin,,,stock wheels and tires dont rub
I had checked for rubbing previously and couldn't see it hitting anything. I checked and it was locked in 4wd, taking it out did the trick. I didn't even notice it, but the stereo installer must have hit it yesterday.
Thanks for your help!
Mine does that with 35's......it's the plastic piece on the rocker panel. I took the cap off the end and its much better now. I also had to remove my front mudflaps. My caster is extended all the way with alignment and the only way to fix is to shim the a frame and I am too lazy to rip into it.
federicoiz
11-19-2011 04:08 AM
novasaigo
11-18-2011 03:24 AM
thehammer12
07-07-2007 12:42 AM
07HummerH3
27
04-09-2007 11:31 PM
