Tire size question also lic tag issue
37X13.50R22 will they fit without trimming or rubbing on 07 H2 SUT (w/o lift).... Also I have the swing out spare tire with the simi hard wheel cover that has the lic tag located in the center. I want to buy 5th matching wheel to mount on swinout spare. Now I don't see a convention relocation spot for the tag. I did see wheat would maybe a place actually under the back above the axle to holes and a rubber gromlet and the tag holes match up! Is this the relocation spot? It's cool if it is but where wolud you guys recommend placement.
Ok checked the bracket again under truck and no... the tag holes do not line up. So that's out of the equation.... The semi hard cover on spare I took off to see how the tag would be mounted if i kept to tag in the center of spare wheel. the center piece is pretty ugly and does not have a finish enough to expose. So is there a cover/mount for center piece/tag to get rid of the semi hard wheel cover and to show off spare wheel.
LastLineOfDefense
12-05-2010 05:28 PM
ArmandoRodz
11-04-2010 09:26 AM
