tire size question
tire size question
I've located an h3 that I really like, and it has 33" toyos. Is this likely to cause a rubbing issue?
Also, what has to be done to calibrate the speedo when tires like that are added? I'm just wondering if the owner corrected for the tire size change.
RE: tire size question
The H3 when ordered with the off-road suspension will come fitted with 33" Dunlops. Speedo is calibrated to correct it, but it has been talked about here that it was still off just slightly.
33s will not rub. If it was a base or Lux with the 32s stock, your speedo will only be off a small amount, like 2mph at 55? You can calibrate the speedo through the PCM, so if you get a PCM tune you can have that done at the same time.
Andreas_Sweden
02-02-2013 09:03 AM
Biggun
11-21-2011 11:57 PM
IN2deep
10-15-2007 09:23 PM
