Tire Size
Tire Size
HI,
I have a 07 H3 luxury package and it is time for new tires. I currently have 265s with the stock 16 inch rims and had decided before I found this website (a couple days ago) that I would go up to 285s and keep the stock rims. But after reading this website it sounds like some have put even larger tires on theirs with no mention of a lift or even leveling the front. Would I have a problem with rubbing or anything else if I went larger than 285? I plan on leveling the front via the torsion bar adjustments next week, then new tires, then aglinment.
Any advice is much appreciated.
Thanks!
Thanks!
Many people have put 33" tires (285/75/16 or 305/70/16) or 35" tires (315/75/16) on stock rims with no rubbing issues. If you do a T-Bar crank to level, the 35's MAY rub slightly on the sway bar at Full Lock of the steering wheel, but 35's will fit without leveling.
I run 33" Goodyear Duratrac's leveled to 23.5" and have NO rubbing issues.
Metric sizing does not convert directly to inch sizing
33x12.50R16 would be closer to 305/70/16
The first number in metric sizing is the tire width in mm
265 = 10.43"
285 = 11.22"
305 = 12.10"
315 = 12.40"
The second number is the aspect ratio, expressed as a percentage of the width. This determines the outer diameter of a tire.
285/75/16 & 305/70/16 are both commonly refered to as 33" tires. Here are the actual numbers
285/75/16 = 285 x 75% = 213.75 x 2 (tire walls) /25.4 = 16.83" + 16" (rim) = 32.83" tire OD
305/70/16 = 305 x 70% = 213.50 x 2 (tire walls) /25.4 = 16.81" + 16" (rim) = 32.81" tire OD
265 = 10.43"
285 = 11.22"
305 = 12.10"
315 = 12.40"
