Timing chain and valves
Hi all,
after some works on my H3 a also change cylinder head for the improved one, but I left same valve shaft. No I have a litle poblem with exact timing of the chain wheels and valve shaft. Do you anybody knows if there is necesity of some speciale tool to time it right way or some other special hint???
Or better way if you anybody have the complete service manual and if you will make a scan or copy of the right part?
Thank you very much
Petr
Thank you very much
Petr
RE: Timing chain and valves
Petr,
If you can't get a good answer from the H3 groups then check the Chevy Colorado groups too...Same engine.
Petr, [/align]Wenn Sie nicht eine gute Antwort von den Gruppen H3 erhalten können dann, überprüfen Sie die Chevy Kolorado Gruppen auch... die gleiche Maschine.[/align]
tmleadr03
01-03-2013 10:15 AM
