Tie Rod and CV Part Numbers?
Can anyone show me on GMPartsDirect.com exactly what needs to be ordered to fix the common breakages of tie-rods and CV's?
For example, I don't know if I need the inner, or outer tie rod, or both?
And I don't have a clue on the CV's...
The outer TRE is usually what bends/breaks, but you should carry both inner/outer to be safe. And you want the larger 16mm ones so get ones for a 07-08 model. I don't have the p/n handy but can get it if you need.
The CV is listed in the catalog as an axle assembly, but gmpartsdirect doesn't show a price. Again, I should be able to get you a part number if needed. Just gotta go through my paperwork when I get home.
If I purchase the entire axle assembly I should just be able to remove the entire old unit and slip this one in while only removing the brake caliper and spindle nut, right?
Thanks Sewie.
Thanks Sewie.
Ridicrick
08-21-2010 08:22 PM
TINKED
06-30-2008 06:17 PM
inked
17
04-26-2007 05:02 PM
