Are there adjustable shocks for the H3???
Awhile ago I installed the Readylift leveling kit, instead of using the shock extenders ( which I thought were kinda cheesy ) I got new shocks, the Pro Comp ES 3000's. It was either the 3000's which are a little softer than the stock shocks or the 9000's which are a little firmer than stock. I do more on-road driving so I thought I would go for the softer shocks, the ride is nice but when I brake the front end dips a little more than I would like. Also when I was in baja not to long ago I actually bottomed out when I hit a small jump( there are tire rub marks at the top of my front wheel wells, guess the bump stops didnt work ) so a little firmer shock would of been nice...
What I want now are adjustable shocks so I can just dial in the ride I like, but apparently there are none out there, I have had 4 Wheel Parts on the hunt for them for the last 2 days and so far nothing is offered for the H3.
So....does anybody know of adjustable shocks that will fit a H3???
RE: Are there adjustable shocks for the H3???
The Rancho RS9000X series adjustable shock will fit the H3. Check angryironoffroadgear.com. I am pretty sure that they have them and can for sure recommend the right adjustable shock with your lift.
I know Rancho makes a 4" lift with these shocks but I am not sure if they will fit the stock mounts. I will find out tomorrow...I would prefer those so I could the remote adjuster, I think it would be nice to be able to adjust the ride as you drive.
MartyMcflyest
09-02-2014 06:54 PM
nuck
09-21-2005 09:27 PM
adjustabel, adjustable, forum, h3, hummer, lift, prorunner, rear, shockingzxcombo, shocks, softer, suspension
