TC on or off?
Old 12-09-2006, 11:31 AM
Sugardaddy's Avatar
Default TC on or off?
Good morning all of you sick-azz mf'ers!!!! I have a traction control question. I have read a previous post about turning off the TC in the snow. First, how is that done? I looked in the manual, but I couldn't find how to. Second. Why? I'm sure most turn it off to have more control, but doesn't the TC do a good job.
Old 12-09-2006, 11:51 AM
hummer plumber's Avatar
Default RE: TC on or off?
Hold the TC button in for about 5 seconds and it will turn off
Old 12-09-2006, 12:21 PM
Sugardaddy's Avatar
Thanks. I'm assuming that this needs to be done everytime the vehicle is started.
Old 12-09-2006, 12:39 PM
That is correct
Old 12-09-2006, 12:45 PM
Sugardaddy's Avatar
Thanks!
Old 01-12-2010, 12:06 PM
achinaghost52's Avatar
i have tried this, i have gotten no indicators or anything indicating the tc is off. i tried it in park, then went out and it still kept kicking in. tried it in neutral, same. drive, same. didnt try reverse though. also tried various lengths of button holding. not workin. have an 05 h2
Old 01-12-2010, 03:29 PM
noavgcobra's Avatar
funny ive tried the same on my 06 with the same results the light flashes but then stops and the tc is still engaged
Old 01-12-2010, 09:03 PM
mx-4-2's Avatar
I just had my '06 H2 in some significant snow. As outlined in the manual, I used the TC2 function which allows wheel spin in low traction situations. When I had this on, I did not have the standard traction control kick in like it does without the TC2 engaged. I don't know if this is a function on the later models or on all years but it worked great in the snow and in the sand last summer.
Old 01-13-2010, 05:04 PM
easy610's Avatar
..me too..
During snow strom this week pushed the TC2 button while in park. Light flashed for 5-10 seconds and went out. Normal? Does that mean it is working?
Old 01-14-2010, 07:33 PM
Trainnwhls's Avatar
no you need to switch to 4 high then you can use the tc2 button and it should stay lit. but if you take it out of 4 high then the tc2 should turn off to.
Quick Reply: TC on or off?
