Tail Light Fuse
Tail Light Fuse
Please could someone tell me which fuse box, and which fuse I need to change for the back tail lights. Brake lights work fine, as well as all the other lights. Its just my tail lights which have stopped working.
Maybe a diagram with a big fat arrow pointing to it. Just to make it really easy for me.
Cheers
Cheers
I'm sure you have found it by now but I think most of the fuses are located under the hood in the black box at the top right. Most of the fuses are labelled. If it's not in there it will be under the dash board, accessed by pulling the side panel off when you open the drivers side door.
A lot of the fuses are coded and without a manual you can't tell what does what. There is also a fuse panel with relays under the driver side dash by the brake pedal. There is also a huge relay on the back of the fuse panel which is in the side of the driver side dash.
flrtrader
11-29-2017 01:19 PM
sullivanjm
05-11-2010 10:39 PM
HUM2
03-07-2007 04:33 PM
