T-Case stuck in 4 wheel low
Hey All,
I'm new to thses forums and I have 06 H3. I did some searching but couldn't find anything regarding this.
I did some wheeling today and engaged 4 low, and now it wont shift out of 4 low. I have used 4 low in the past and had no problems going back to 4 high. I have tried everything and it simply wont shift out of 4 low. The light never blinks when I push the button. I spent arounf 45 min trying everything with no success.
The car is stuck in vail at the moment so any advice you have would be greatly appreciated.
RE: T-Case stuck in 4 wheel low
did you try going in reverse about 5-10 mph while turning left and right...this should kick her out of 4-low. If not, try going under and unplugging the plugs on the t-case.....clean em out then plug it back in. This connector has given people problems in the past.
That's good advice. One thing is that there is no feedback if I push the buttons. They never blink or anything when I push them. I'll do what you mentioned because I did go through some water and mud after going into 4 low. Thanks again.
