Suspension ?
Old 07-24-2006 | 01:01 PM
Sugardaddy's Avatar
Default Suspension ?
I was looking at the front suspension yesterday, and although I don't know what a Pitman or idler arm is, the tie rods appear to be quite thin. I know that I have read about this being the weak link. Under what circumstances would it be recommended to replace these parts? Could these possibly break under relatively "normal" driving conditions?
Old 07-24-2006 | 01:37 PM
shortbus's Avatar
Default RE: Suspension ?
if you look at the connecting rod between your tie rods, there are two other pieces connected to it, that have grease nipples on them. one on the left, one on the right, those are your pitman and idler arms. they have a tendency to wear out over time, but i haven't heard of one breaking. as for the tie rod ends, they are pretty small. typical driving conditions shouldn't be a problem, unless you have a habit of hitting curbs alot. they tend to break when one of your front wheels is against an immovable object (boulder, curb, etc.) and you try to turn the wheel. the power steering is strong enough to snap the one that's stuck.
Old 07-25-2006 | 04:19 PM
Sugardaddy's Avatar
So are you guys replacing these aformentioned parts?
Old 07-25-2006 | 09:29 PM
blackstangs281's Avatar
If you are going to go play in the mud, it's a good idea to replace them (if nothing else...piece of mind). But for every day driving, They will be fine...................unless you run over a Prius, they tend to wrap around the tire and bend the tie rod.[sm=gears.gif]
Old 07-26-2006 | 01:49 PM
Sugardaddy's Avatar
Is it only the tie rod ends that should be replaced?
Ta Jay
02-11-2008 12:46 AM
stallioncustoms
21
10-25-2006 08:37 PM
New Yeller
09-02-2006 08:05 AM
steelcity
07-11-2006 06:56 PM
ogdel314
04-25-2006 11:44 AM
