Sunroof express open
I have a 2007 H3 and when I open the sunroof it express opens almost all the way. I would say 95% open, but if i want it completely open I have to push and hold down the button again. The reason I ask is the manual says the sunroof will "completely" open once you push the button. I would of never noticed it but I pushed the button to see if it would open more and it did. Is this normal or is mine malfunctioning by not opening all the way??? I have 3 more months on the warranty.
Edit: Just checked the owner's manual, and it doesn't even explain this! It says it's fully opened after press and release!
Open/Close: Press and release the back of the switch to
fully open the sunroof. If the sunshade is in the closed
position, it automatically opens with the sunroof. To stop
the sunroof before it reaches the full open position press
and release the front or back of the switch. An air
deflector raises when the sunroof is fully opened.
Just an FYI ... I opened the sunroof automatically and after it stopped I also noticed that it could open some more so I did, but then it would not express close or open. If this happens you need to close the sunroof all the way then reopen all the way but hold the buttom for at least ten seconds after it is full open. Then close and it will work correctly. Some sort of relearn for the module.
When you open the sunroof that remaining amount, at decent speeds you get the pressure build up in truck and is annoying. I believe it was a design flaw and gm engineered it to open to that spot on the first button push before there is a pressure issue and push again to open all the way.
khelms_98
12-25-2006 04:38 PM
07-19-2006 03:05 PM
