stripped skid plate bolt.
Old 08-20-2007 | 10:26 PM
jm4490's Avatar
Default stripped skid plate bolt.
So while trying to do a good thing and replace the factory oil I noticed one of the skid plate bolts was not going without a fight. So i went so an got it out,changed the oil , started to replace plates bolts. I put the bolt that gave me issues back in but not all the way. Anybody have these issues and how would i go about fixing that one bolt/threads.
Old 08-20-2007 | 10:55 PM
importkiller's Avatar
Default RE: stripped skid plate bolt.
is it stripped? WHich bolt is it? If it's one of the front ones then you can just go to gm and buy a replacement nut clip. The back ones I am not 100% sure if they use a nut clip or if they holes are actually tapped. I would buy a nice cheap tap/die kit and using the the correct die, run it up and down the bolt a few times to clean up the threads then take a tap the same size and thread pitch and run it through the hole a few times...this will clean up both sets of threads and it you'll be good to go.
alrock
09-17-2018 10:37 AM
Justinh
03-04-2014 04:54 AM
TPsCherryH3
11-02-2012 07:21 PM
heyttsguy
04-24-2011 12:23 AM
tomp
09-17-2007 02:20 PM
