stock tire on what rim...
RE: stock tire on what rim...
Mike, H1, H2, H3 ???? I put H3 info on here. If you go to a 16x9 you need to make sure the offset is adjusted so you don't get any rubbing. The two websites help you see and plug in the numbers to show you what would work.
http://www.wheelsmaster.com/rt_specs.jsp
http://www.dakota-truck.net/TIRECALC/tirecalc.html
H3 info:
OEM tires: 265/75-16 (802x265mm). Big Hub.
32 x 10.5 x 16
Bolt OEM tires: 265/75-16 (802x265mm).
Bolt pattern: 6x139.7 (6x5.5).
Offset: 15 to 35 mm. (or Backspace)
Tires up to 842x305mm.
Rims up to 26x10.0".
265/75R 16 = 32 X 10.50 X 16
265/70R 17 = 32 X 11.50 X 17
275/70R 17 = 32.50 X 11.00 X 17
285/60R 18 = 32 X 11 X 18
H3 info:
32 x 10.5 x 16
tschtulmann
04-04-2009 05:28 PM
BMoney5327
03-24-2008 05:33 PM
