Starting problems with the H3?
Old 05-06-2011 | 08:22 PM
thedave8's Avatar
Originally Posted by HawaiianH3
Having this same problem! Started right after I bought it, shoot some Graphite lube in the key hole which helped for a few weeks. Then bam.... again this morning. This problem is not related to hot or cold engine, its related to the cheap tumbler they built in it and Im gonna have to replace it. Only about $60 on ebay!!! Thanks for the thread! RED BLINKING SECURITY LIGHT ON THE DASH will let you know you have the "IGNITION DEATH!"
its not the tumblers that go bad, is the electronic security stuff in the electrical part of the ignition switch....tumblers would not let you turn key.....
  #22
Old 10-18-2012 | 02:59 PM
r.spoonemore's Avatar
Default starting problem on 07 H3
I have had the same problem with my 07 H3. I have had 2 mechanics tell me it had to be the fuel pump. I didn't believe them but changed the fuel pump, problem still exists. Very intermittent maybe once every two or three months. Doesn't matter if it's cold or warm and like others, after 10 or 15 minutes it fires right up. I thought from the beginning that it might have something to do with the anti-theft system. I quit using the remote on the door locks for a while and went for several months without any problems but then it happened again. I still think it is some problem with the anti theft system. Anyone found a solution?
  #23
Old 10-18-2012 | 03:23 PM
rtwash
12-13-2013 11:45 PM
ggammariello
07-19-2010 08:45 AM
bump535
07-28-2009 07:47 PM
tenrten
01-12-2009 11:30 PM
herecomesthepain
01-26-2008 09:43 AM
