starting to make it mine
Old 09-03-2013, 01:22 PM
skeeter's Avatar
I found 315s for 250 a piece, but they are an off brand made by goodyear. Fierce attitude M/Ts
  #22
Old 09-16-2013, 06:47 AM
spazz8448's Avatar
Originally Posted by telemike
RETURN THE LIFT KIT. YOU DO NOT NEED IT.
You can fit the following on a STOCK H3:
285/75R16
305/70R16
315/75R16
A 1/2" drive breaker bar and 27mm socket is all you need to turn the torsion bar bolts. Measure from center of the axle shaft to the wheel well. Do not exceed 24". 23.50" is max for safe CV shaft and steering angles. Stock should be 22.50". No adjustment to the rear needed. Adjust to desired height, drive around and work the suspension. Re-measure and adjust until it settles where you want it. Then get an alignment.
https://www.trailduty.com/product_in...0ee2f9d53aa9df
which should i order? the 1/2 or the 1. im not anywhere near my truck and i wont be for awhile. im just trying to get the parts together for when i get home
  #23
Old 09-16-2013, 07:12 AM
telemike's Avatar
1/2" extended bump stop.
  #24
Old 09-16-2013, 07:30 AM
Ground Pounder's Avatar
I'm gonna have to save this thread in my favorites, good info..
Mountain Trooper
06-03-2007 06:56 PM
HummerGuy
28
02-22-2007 01:40 PM
williecee
19
12-03-2006 04:44 PM
dilo2001gt
09-21-2006 03:06 PM
jaycen29
20
07-01-2006 11:57 PM
Quick Reply: starting to make it mine
