Stabil Trac Error...
Old 12-19-2012 | 12:55 AM
Happy Hummer's Avatar
Default Stabil Trac Error...
This began back some time ago...
GF's 84k 06 H3
Early am hours she starts the h3 and she gets a brief Stabil Trac Error...
We have been addressing many items with this h3 & it is realy agravaiting to say the least.
All the following are addressed:
MAF cleaned
TB cleaned
Intake cleaned
All connections cleaned and checked (DVM'd as many circuits as posible)
Clean air filter
New battery and connectors
New spark plugs and #1 coil replaced
MAF connector (weather pac disassemb and cleaned)
Reset all codes
Truck is running really pretty good but DIC keeps coming up each morning.
One other thing...
It happens under 37* & now only for brief moments. Only for 1st start of the day.
Any thoughts?
Chris
Old 12-19-2012 | 09:49 AM
2wheelmonster's Avatar
I know when this meessage came up on mine it was the BCM computer, because mine was under warranty I took it in and the dealer came back with that replacement. Hope it helps!!!
Old 12-19-2012 | 10:34 AM
Bigunit's Avatar
Mine started doing it off and on when I would apply the brakes to come to a stop - I'd get the "stabilitrac system failure" on the DIC & my taillights wouldn't work. It would reset itself, go away, then come back on a few stoplights later.
My problem was a bad "stop lamp brake pedal switch" - GM part #15914909. Easy fix, covered under warranty. If your service rep. starts giving you a song and a dance, tell them to start with that easy diagnosis - as the code that they will pull up, will confirm that is the problem - if that is the problem. Good luck. let us know what your or the service dept. comes up with. My GM service rep. friend tells me it's a common issue/fix with H3s/H3Ts.
Old 12-20-2012 | 01:10 AM
Brake switch seems to be working correctly by all accounts. BCM hmmm interesting... hadnt thought of that.
Chris
LouieB!
01-04-2014 08:58 PM
T REX
09-06-2008 03:14 PM
Northerner
16
07-16-2008 10:46 PM
opulido
02-23-2007 09:53 PM
importkiller
02-03-2007 11:22 AM
