Stab trac control fail?
I've been searching through old posts but can't seem to find this issue alone.
I was driving over a patches of ice on my way home today and when I hit my brakes I just slid. My traction control light came on and said "stab trac control fail service". Every post I came across had this issue in conjunction with the abs light, where mine was just traction light only.
Any ideas? Where to begin?
Looking a little bit more and found this
https://www.hummerforums.com/forum/h...s-codes-10767/
Going to try to cycle from 4/4hi/4lo an then check the tccm and see if that helps.
Well the trac system fail went away but in the process I fount that while alternating between 4/4hi/4lo that it won't lock into 4lo. The light just keeps flashing on it but won't go steady and it won't click in like it did for the others. Also when I hit my rear did lock there is no audible noise or the light won't go steady.
Any ideas?
Any ideas?
I didn't know that, but I knew the light should stay steady. I didn't try it in neutral though. Just park and all the drives.
Yeah, I found them. Everything works fine now. Just took a little bit.
Shorty
06-23-2015 09:12 AM
brachilius
28
02-03-2011 08:04 AM
ockie
07-26-2008 06:44 PM
