Squeeks when going over bumps
Where at? Front? Rear? Suspension? spare/gate?
The leafsprings are notorious for squeaking. Hitting them with a high pressure wash to clean all the crud out from between the leafs will often substantially reduce or eliminate the squeaking.
Squeaks
Mine was doing something similar and it turned out to be body mounts. Still under warranty, so it was taken care of.
I had a severe case of the creaks whenever I turned left or right or went over bumps.
At first I went over 4 to 6 joints in the front end with WD-40. There was little improvement so I considered taking it to the dealer. The next day I decided to go over everything and I mean everything. I got on my back under the H3 and discovered joints I had missed under the front end.
Upon standing and looking down between the tires and wheel wells I sprayed the shock joints bottom and upward toward the tops even though i could not visibly see the joints. I found other joints in the area too. Next I took care of the rear shocks (even up into all of the shock covers) and even the leaf supports and any and all else. I am here to say all creaks and squeeks are GONE and I am glad I did not give up after the first try.
hummerdoomed
64
04-04-2016 03:59 PM
Piranha
21
04-02-2016 09:00 AM
mnext02
07-13-2011 10:01 PM
Indy
02-24-2011 12:23 PM
